im planning on painting my brake calipers red.. do i need to use a special type of paint? what works best? where would i find it?
caliper paint
Re: caliper paint
i used a duplicolor paint on kit and it worked great and looks good. only think i didnt do was clear themLast edited by Mystic98; 07-29-2006, 12:17 PM.98 Mystic Teal Camaro
Mods: FRA, K&N, Clears corners, runing lights, billet grille, All blue interior leds, All four highbeam mod, Halos
Re: caliper paint
They have High temp Caliper piant, go to like auto zone and such. Also make sure you scrub those suckers good before you pain them. And let the coats dry at least 30-40 mins in between. Good luck!
1998 White Camaro 3800, A4, MagnaFlow Cat-Back, Zexel & 3.42's, Jet Chip Stage 2, Whisper Lid, and Ram Air.
Re: caliper paint
Ya a bottle should be fine, I would look into getting some high temp clear coat also. This site sells cool Camaro decals for you brakes, they look real neat when they are done. http://fourthcircledesigns.com/index.php?cPath=2
Re: caliper paint
I used the Duplicolor brake caliper paint kit. It comes with everything you need. No clear coat is required.
Thats what mine looked like after they were done. Also, its been a few weeks now atleast and they are still looking as good. I paid about 15 dollars for the kit. Be prepared to take a while to paint them. Those back ones are time consuming.
Edit: Nevermind, I just saw that you were doing the front ones. They are pretty easy. Heres a picture of the front:
Re: caliper paint
i got filler primer, high temp paint and then some clear coat. all from autozone
http://forum.camarov6.com/showthread...light=calipers
Re: caliper paint
pepboys, autozone, advance auto all those places have the caliper paint. what i did was buy engine primer, engine paint, and then engine clear coat. the engine stuff works just as good cuz its meant for high-temp areas. make sure you sand down the calipers to get all the crud off of them. i sanded them down, 2 coats of primer, 2 coats of paint, 3 coats of clear. took a lot of time but they look really good'99 Camaro Y87 M5 T-tops
Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
Car Domain
by 2.8 BirdSo there going to be anything new or update to the site since Bill is now the owner?
I know there's still alot of interest in the fbody V6....3 days ago -
by FirebirdGTAll - sorry but there seems to be some glitches from moving to a new Host - hopefully they will be fixed soon.
If needed you can email me...2 weeks ago
