Removing the Black Front Grill - FirebirdV6.com/CamaroV6.com Message Board
  • Removing the Black Front Grill
    I think im going to remove the black front grill...because i keep seeing camaros with body benath is as the same color as the car with camaro written across and many of ur camaros have...now im assuming that is behind the disgusting black grill? or is that some other mod u all put on...and if that is behind it...is there ne trick in getting the black off
    Re: Removing the Black Front Grill
    if i remember correctly when i put my billet in, i believe it just pops in and out of place, i had to kind of "wrestle" w/it to get it out but it was just held in by clips. anyone else chime in and correct me if im wrong. its been 2 years atleast so im not positive, but sounds right to me.
    \"there are things known, and things unknown, and inbetween are the doors\"-jim morrison<br /><br /> <a href=\"http://www.cardomain.com/id/99NBMCamaro\" target=\"_blank\">http://www.cardomain.com/id/99NBMCamaro</a>
      ok cool...and when u took it out...there was that body peice behind it??
        yep. and all you do is pull!
        Dave:
        00 Supercharged Camaro - RIP
        97 Turbo Camaro - Sold
          yeah just pull and there is the body panel right under it, i bought camaro letters to stick in there. but there are the mounting holes there too if you take the stock grill off, it can look kinda dirty. heres a pic you can see the inside part real well
            Bare in mind that when ripping off the grille you don't rip off the bumper. Mine was stuck fast and i had a hell of a time cutting the top connections. But regardless of what Kristen says, our cars look 39752957 times better without it. :banana:
            Originally posted by SSMOWS6
            i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
            R.I.P. '07 Pats
            Still... 18-1 > 1 and done
              ok cool...thanks for all the help
                You people that live in states that dont have to have front plates S*CK.
                Damn I wish I could do that.
                Left turn Clide.
