thinkin about ordering these. my car does not have fog lights and I am wanting to install some that will bolt up to factory locations and use the factory switch,(if I can find one). will these bolt right up or will I have to get some other brackets too?
It looks like the brakets are attached to the lights. You'll have to do the wiring though. Does your camaro have a harness attached to accomodate for the lights? If not, see if you can find a harness on ebay or j-yard.
well the lights are a good deal price wise but I can't see the wiring coming out of it so you always have to question that. our cars already come with the wiring and connector up the the light and switch.
I found the wiring on the inside that goes to the switch but I coud not find the wiring outside under the hood. In the fuse box i saw where the relay is supposed to be for the fog lamps however, there was no relay in there nor was there any wiring coming up from the bottom. So where does the wiring stop?
if you look real close under there where the fog lights are, you will eventually find the wiring and connector. ofcourse the relay or fuse wont be there but the wiring should be.
I looked every where for the wires and could not find them. There is no wiring going up to the fuse block under the hood where the fog lamp relay is supposed to plug in. I also looked where the fog lights mount and did not see anything there either.
