I was just wondering how many times you can use 1 claybar? I got the Meguiar's kit and it came with 2 bars. How many times can I use the 1 bar since it will absorb more and more dirt each time? By the way i recommend the Meguiar's kit to anybody!
How many uses w/ claybar
Re: How many uses w/ claybar
I have used mine quite a few times. I think usually you use it tell it falls apart or whenever you feel it is too dirty for your paint.
Originally posted by carl g. berlinI just clayed my car this past weekend with the meguires. Damn that stuff works wonders. My car is black, and it looks as if the paint is new!
well it comes in a kit. I got the mothers ( though im a Meguirs fan through and through, but was the only one at Advance) it comes with a clay bar, a special spray, and some wax. you take the spray, and squirt it on your paint, workin small areas at a time, then you take your bar (i take half of it) and rub it in the area you put the spray down, and periodically, rollthe clay back up in to a ball cause the dirt collects on the bottom and you roll it up and start with a new patch. DO NOT rub on a dry area, you might as well take sandpaper to your paint. after you hit the area, ittl leave a little white residue, just wash your car good, and wax it. itll be the best hour you spent on your paint
(note: wash your car before doing this this is justto get the particles in the paint out and other contaminents, and wash it after you clay it)
