pwoder coated intake with pic's - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: pwoder coated intake with pic's
    did you buy one of those powder coating guns from like sears or harbor freight, where it looks like a 12 volt cordless drill?
    Looks pretty nice, a friend of mine bought one of those and powdercoats motorcycle parts. It turns out pretty nice.
    *Matt
    • #17
      i have a system called HOT COAT. from some people the do it for a living.. i like it, it works for the stuff i do..
      • #18
        If the intakes arent port matched, they arent going to do anything
        (port matched = upper and lower both P&P'd to the same specs, and the lower port job flowing into port matched heads.)
        plus if you not very experienced in porting, then this would be a bad business venture as there would be many complaints.
        • #19
          I was thinking about that too. Just have to order the P&P heads and intake from Abbot or whoever and then send that to him wait to get them back then send the cores back. Still to have candy apple red intake and heads would just be pure sex.
          • #20
            how much would u be willing to pay for my dirty one?
            • #21
              well if you wnat one p/c. ill send you one in any color you want. then you send me your old one. and ill give you some money "it's like a core charge" i dont care if they are dirty i clean them right up b4 i P/C them any way... but if they are cracked then i dont want them cuz noone whant a cracked one lol....
              • #22
                so what is the actual temp rating on powdercoating?
                http://www.bowtiev6.com/
                • #23
                  i am not sure but i know some people have done their Turbos and headers and what not with high temp powder coat... the stuff on the intake is more then enough for the intake heat range
                  • #24
                    so $350?
                    come get some
                    http://www.canyoumaketheturn.com/
                    • #25
                      350? for what? ill sell a p/c intake $90 but if you want one that has been ported. just send it to me after you ported it...
                      • #26
                        you know. valve cover would look good to:naughty:
                        • #27
                          hmmmmmmm i'll have to think about this one, and i was talking about a p&p job also.
                          come get some
                          • Andy H
                            Transmission removal help!!
                            by Andy H
                          • 2.8 Bird
                            Abs inop
                            by 2.8 Bird
                          • fishin
                            by fishin
