how do u do it on a 99 i know there are two clips on the left and right side
how do u remove front grill?
Re: how do u remove front grill?
If your not going to keep it then pull the left and right side off. Then there will be I belive 4 clips, two top two bottom, just reach in with something to cut them off. Then it will pull right off. If your trying to salvage it, I guess try and squeeze the center clips from the back and push them through the front.Let's flip a coin. Heads I get tail, Tails I get head.
be careful with the front air dam because it will flex a lot but don't push it because too much and you'll be asking how to remove the front fascia.Let's flip a coin. Heads I get tail, Tails I get head.
the correct way however, involves removing the whole front bumper, of course few actually do this.
