how do u remove front grill? - FirebirdV6.com/CamaroV6.com Message Board
  • how do u remove front grill?
    how do u do it on a 99 i know there are two clips on the left and right side
    Re: how do u remove front grill?
    If your not going to keep it then pull the left and right side off. Then there will be I belive 4 clips, two top two bottom, just reach in with something to cut them off. Then it will pull right off. If your trying to salvage it, I guess try and squeeze the center clips from the back and push them through the front.
      ok thats what i thought i just wanted to make sure i wasn't going to break any thing
        be careful with the front air dam because it will flex a lot but don't push it because too much and you'll be asking how to remove the front fascia.
          lol ok i will
            in short, this is what you do:
            PULL.
            Dave:
            00 Supercharged Camaro - RIP
            97 Turbo Camaro - Sold
              the correct way however, involves removing the whole front bumper, of course few actually do this.
              Visit My F-Body Page
                easiest way is to get the bottom out...and then use a falt head screw driver to pry the top peices out bc they are harder to get out than the bottom...thats what i did
