my 1st attempt at polishing - FirebirdV6.com/CamaroV6.com Message Board
  • my 1st attempt at polishing
    well i got this wheel smoothing/buffing kit from eastwood the other day. the box absolutely reeked of some kind of dead alien carcass... i did a couple of spots (one portion of a centercap and one spoke) on the worst looking wheel. i dont know how many of you realize, the oem salad shooter wheels are rough cast, sprayed with a heavy primer, basecoated, and clearcoated (painted) and it takes a good bit of work to make them look good again. i suppose you could just repaint them but no, i have to be different.
    i stripped the paint off the face of one spoke and went to polishing. the centercaps however just need to be wet sanded and polished. ill get to that in a minute.
    the kit is simple really. it comes with 4 of one kind and 1 of another kind of 4" buffing wheels, 2 "goblet" shaped buffs (for getting in the corners) with the necessary arbors to chuck the buffs in a drill or similar tool. i tried with a right angle die grinder (mines a bigger die grinder than most, i dont know how well a cheapie would do) but its hard to regulate, they need to be spun at 2500 to 3000 rpm no more no less. id just stick with an electric drill.
    the kit also comes with 3 grits of greaseless cutting compounds (80, 220, 320)for smoothing the material. there are also 2 different polishing compounds (tripoli and white rouge) that are a part of the kit. essentially you use the compounds starting with the rough grit working your way to the finer grits. be sure to wash the wheel thouroughly between compounds and the application of the compounds can be trying. you have to rub a small amount of compound or polish to the spinning wheel, it will melt the compound onto the wheel. let the compound dry completely (10-15 minutes) and you can proceed to buff. they say strike the buff with something like a screwdriver handle to improve flexibility of the buff, i can guess do this while its NOT in motion but they dont mention...
    after all the compounds and washing you should end up with something like this:
    probably needs more polishing...
    now, about the center caps. these have a chrome coating on them, they are not metal of any kind. if you polish/wet sand too much you will pretty much ruin them. with that said here is what you can achieve with 1500 or 2000 wet sand paper and some polishing compound:
    now like i said this is my 1st attempt, so i think it will only get better. more pics to come when at least one wheel is completely done.
    foggy headlights? wetsand... buff... WAX!!!
    if nissan motorsports is nismo does that mean honda motorsports is homo?
    Re: my 1st attempt at polishing
    Have you tried handsanding the wheels (not centercaps) with some rougher paper and working your way up. the texture looks like it could be flattened out with about 300 grit or so, and then working back up to 2000. you could probably get a nice shine out of them that way.
    Visit My F-Body Page
      thats what the greaseless compounds are for. i didnt use them properly on that one spot. i need to get an electric drill as the compressor i have dosent really keep up with my die grinder. that and i didnt let the compound really dry. originally i had wet sanded that one spoke to remove the paint. compounds are quicker... trust me. less scratches too.
      what i need to do is break the wheels down, no tires, valve stems, or weights. kinda difficult with that car being my dd.
        That's looking quite good, like loochy said, smooth it out a little, and it will probably get better the more you do. Good job, and good idea.
        How much was the kit you used?
        Pics for sure when you're farther along.
        1996 Chevrolet Camaro
        1995 Buick Park Avenue Ultra
        --Appearance Moderator--
          If you polish into those centercaps too much you should be able to spray paint them again. My centercaps were painted silver just like the rims and I got some duplicolor and made them look ALMOST as good as originally. I need more practice at it though, just getting the roughness out.
          Nice work.
            heres the exact kit i am using:
            http://www.eastwoodco.com/shopping/p...iProductID=953
            camarorulz if you can find a single stage paint, be it touch up or aerosol, that will polish like that let me know! ive found aerosols that will create a finish like that but with a lot of prep and even some paint work. whole 'nother story in itself....
              i might try that on my shooters...i love the chrome salad shooters so ill try to get em good and polished up
              87 Firebird RIP
              96 Camaro RS RIP
              94 Patriot Red 1LE Z28 - Sold
              02 WS6 TA - Sold
                hey your white
                2002 Firebird<br />2003 Yamaha YZF 600R
                  me too
                    Originally posted by redbird00
                    hey your white
                    what? :poke: that's not even the correct use of "your"
                    not bad. keep the tips coming.
                    http://www.cardomain.com/ride/2287597
                    :( SOLD! NO LONGER A CAMARO OWNER :(
                      any new pics yet?
                      87 Firebird RIP
                      96 Camaro RS RIP
                      02 WS6 TA - Sold
                        CamaroJeff, as far as I know Duplicolor makes a chrome type paint that might match those. When I repainted my center caps I just sanded down the paint that was on there and re-sprayed. I gave it two coats I think, applying it as evenly as possible. I need to work on wetsanding and everything to smooth it out, I just haven't had time.
                          i've yet to find any chrome paint that comes even close to that, the stuff i've used is just like extra shiny silver. I might have to check out duplicolor.
                            The duplicolor chrome paint is no different than the rest of the so called chrome paints. It's just an extra shiny silver.
                              duplicolor chrome paint = :tdown:
                              they even use a real chroming process to color the lids to mislead.
                              you might try this: http://kustomrides.com/xcart/Killer-...Can-p-486.html
