Cleaning Engine Bay- What to use? - FirebirdV6.com/CamaroV6.com Message Board
  • Cleaning Engine Bay- What to use?
    Hey all, my engine bay is pretty darn dirty, i don't think it's ever been cleaned before, without taking the entire engine out, whats the best way to clean all the metal and plastic? What kind of cleaner do you reccomend? Should i make sure to stay away from certain things? (besides the obvious) thanx
    Re: Cleaning Engine Bay- What to use?
    I use just a plain degreaser and a can of CD2 engine detailer after that. It works pretty darn well and just use a wire brush to clean off some of the stubborn parts in there! Just make sure you cover up all the electrical parts with plastic bags (PCM, Alternator, wires, ect.)
    Here is a pic of how well the CD2 worked on my engine bay!
    1997 30th Anniversary Camaro.
    SLP CAI, Dynomax, PCM tune, SS Hood, Clear Corners, T-Tops, Sony Xplod
    TEAM RED
      hey looks great man, can i get CD2 at a regular auto store? How do you apply it? And you say cover the electrical wires and such...does that mean you spray the whole engine or you just go piece by piece...thanx
        another cd2 user here. make sure you hit all the rubber with some kind of rubber protectant to shine it up nicely.
        Visit My F-Body Page
          oh yeah, you can get CD2 at any auto store. I just wrapped the electricals in plastic bags and sprayed away. It is in a aerosol can so you just spray it liberally (Democratically... :) all over the engine, let it sit for while then start the car and run it a little bit and it burns some of it off. Then I just whip it down and clean it up and hit it with some rubber protectant. From my experience, NXT Tech Protectant works pretty well for that part. Good Luck
          TEAM RED
            wow that came out very nice. i might be trying this one of these up-coming weekends
              Looks good. I've heard a lot of good from that CD2 stuff, but i also heard that it was recalled and unavailable at stores. Is that still true? Also is that NXT protectant just a basic rubber/vinal protectant like armor all?
              Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
                thanx for the instructions...sounds like fun now... guess i'll have to turn democrat for a while huh? :)
                  hey red demon...any particular reason why your fuse box cover is off in the picture?
                  • Andy H
                    Transmission removal help!!
                    by Andy H
                  • 2.8 Bird
                    Abs inop
                    by 2.8 Bird
                  • fishin
                    by fishin
