Quick Night Shade question - FirebirdV6.com/CamaroV6.com Message Board
  • Quick Night Shade question
    How many coats of VHT Night Shade do you guys suggest I put on my turn signals?
    I searched and didnt find anything for turn signals, just tail lights. :)
    TIA
    1997 Camaro RS A4
    2006 Chevy Colorado
    2003 Kawasaki Ninja ZX6-R
    Re: Quick Night Shade question
    clear corners ftw
    sry that my opinion was not more helpful
      Originally posted by Niko97RS
      clear corners ftw
      Clear corners would not look as good with my black/white theme.
      1997 Camaro RS A4
      2006 Chevy Colorado
        id go with 2 or 3 light coats and see what you think
          can says 3 max
          1999 Camaro Z/28
          1973 Firebird Formula
            ive hurd of ppl having up to 4 light coats on them.. thats why i said 2 or 3
              2 or 3 ide say, i think i did way too many coats on my tails and now there darker then my blackouts were and can barely see the signals/brake's when applied i wanna lighten them up but idk how...
                try wetsanding, thats how i lightened up my corners when i made them too dark.. keep your sanding even though:cool:
                  When you hit your brakes, doesn't this dim the light?
                  Lounge Moderator
                    sorry to be the dumbazs off the group but what is vht nightshade?
                      ^ your spray it on turn signals/brake lights for the "black out" look
                      speaking of which.. where can i purchase it at? i was told pep boys, but there is none near me, does any place else sell it?
                        just google it and get a can online. I did and paid like $4 for it to my door. I did 3 on my turnsignals and 2 on my tails (wanted tails abit lighter since they're altezzas). Turned out nice, but don't forget to clear coat one you're done :D Otherwise it looks orange peely most of the time.
                        ~97 3.8L V6 Camaro~
                        A few things
                        Only Member of Team Hooker?!?
                          ok thanks, and do you spray the inside or outside of the light? and also is there any prep work? or just make sure its clean? and what kind of clear coat?
                            I sprayed the outside, but I've heard of people pulling them apart and spraying the inside, I guess so they don't get scuffed up and stuff, but o well. Mine came out pretty good. They do have blemishes from my lack of paint skills, but they're only visable up close. And any kind of clearcoat should do. I'm sure people have preferrences, I personally used DupliColor from Wal-Mart. Just make sure they're clean, I wash and dry mine in the sink before I paint. Make sure you have some fine grit sandpaper to fix any screw ups you may make (I thought I had some, but it wasn't fine enough and didn't help any). I usually do one coat, go spray the other lense. Wait about 2-3 minutes for them both to tack up, then go and spray the next coat. If I see any runs or anything, I let them dry another 5 min or so and then wet send them down and redo the last coat. Once I get them dark enough, I put a coat of clear down, again 2-3 minutes after the last coat.
                            ~97 3.8L V6 Camaro~
                            A few things
                              I'd have to disagree :cool:
                              Visit My F-Body Page
