Undercarriage-front driver side - FirebirdV6.com/CamaroV6.com Message Board
  • Undercarriage-front driver side
    I just went outside and looked under my car and BAM!
    i can't really explain it... so maybe i'll go take a picture of it. but it's cracked, i'm so pissed.
    Re: Undercarriage-front driver side
    alright here are two pictures... i tried to get the best shots
      somebody didnt use the right technique while jacking the car up...
      foggy headlights? wetsand... buff... WAX!!!
      if nissan motorsports is nismo does that mean honda motorsports is homo?
        :'( i haven't jacked the car up yet.. those bastards...
        so what should i do about it?
          well someone tried to jack the car up. do you have wheels that might be attracted to sticky fingers?
          youll have to take those 2 bolts out, clean that area thats cracked, etch it somehow, and glue it back together. unless you have some plastic repair hanging around id try (i hate to say this but it works) jb weld. so long as you get the area clean and roughed up well enough the adhesive will hold. then just spray a little touch up on that spot. probably wouldnt hurt to put some kind of reinforcement between the fender and the adhesive.
          after a few miles of driving there will be enough road dirt covering it up you probably wont even notice.
            no, my wheels are stock.
            thanks for the help. definitly get that fixed asap.
              I dont think you have anything to worry about really.
              *Matt
                if youre worried about something breaking StrtRacer98 pretty much said it. its not going to cause any problems down the road.
                if youre worried about looks well... you have the info to fix it.
                either way have fun and try to figure out why it happened in the 1st place. looks like it was fairly recent...
                  i got the car on the 4th of april.... and i got it from a dealership. so i don't know
                    -Remove the two attach bolts.
                    -Take a #30 or 1/8 in dia drill a stop hole right at the crack leading edge or apex.
                    -Using sheet metal (i would use .040" aluminum, with about a T3 hardness, but really any metal you got kicking around will do the job) I would fabricate a doubler repair with an 90 degree angle bent into it and I would glue that to the back side of the panel, with the angled part orientated down, to match the shape of the panel.
                    - Using the attach bolt holes in the panel as a guide, match drill the attach bolt holes into the metal doubler.
                    -Make sure the bracket that the panel attaches to is straight.
                    - attach the re-inforced/repaired panel with the attachment bolts to the bracket.
                    After that, you will never have to worry about that crack getting worse.
                      Here's a pic from another thread by strtRacer98
                      .... maybe that's why his car spend more time on towbeds than the road!
                      09 Nissan 370Z MB M6 Sports Package
                      www.the370z.com
                        LMAO Thats good right there!
                        *Matt
                          thats a common problem. you have nothing to worry about. take a picture of your front fender where it lines up with the door. is that lined up right?
                          Visit My F-Body Page
