I just changed out my cluster in my 94 camaro, and put a cluster from a 97 3.8. I was shocked that it worked, but it did. Just wondering if a cluster from a 93-97 Z28 would fit into a 94 3.4?
Just changed out my old cluster.
Re: Just changed out my old cluster.
speedos are diffrent and would need recalibration of some kind. Not sure of the exact need of adjustment just know it would be off in the speed slightly. I think it's been discussed on here a few times but not sure of the resolution.Let's flip a coin. Heads I get tail, Tails I get head.
i think the bigger problem is the tach, supposedly it would be completely off. Since it's electronically controlled, i'm not sure if the speedo would be off or not. Not sure if you could since you can't use hp tuners or the like on your 3.4.
btw, it's 93-96, dash changed in 97.
