Finished the Camaro - FirebirdV6.com/CamaroV6.com Message Board
Finished the Camaro
  • Finished the Camaro
    Finally after working on the thing for countless hours, Im finished til fall.
    Looks stock, but here are my following mods.
    BMR Strut Tower Brace
    Bilstein HDs
    32mm front bar w/ greasable poly bushings and poly end links
    19 mm rear bar w/ greasable poly bushings and poly end links
    Hotchkis Box LCAs
    Hotchkis Panhard bar
    LT1 Torque Arm w/ Poly bushing
    Poly trans mount with 3/4" metal spacer
    Aluminum Driveshaft
    Torsen Diff w/ 4.10 gears
    FIPK
    Flowmaster Catback
    B&M shifter
    Ill get more pictures when I can
    Re: Finished the Camaro
    looks like your leanin pretty hard on the suspension upgrades? i bet it handles like a beast thought.;)
      Yeah, how much did that suspension setup cost you?
        suspension was about $700 I installed myself, probably the easiest part of the car except the shocks. Took me about 5 hrs for everything.
          Cool. How much do you think it would cost to be installed by a shop?
            Probably 400-500
