just got my clear corners in today, the front ones, before doing the install i was wondering if i could get some tips from anybody who's done them before on a 93-97 firebird. I see there is some room to reach my hand when the headlights are up, but i don't know if that's enough room. Should i go from under the car? What tools do i need? any help would be appreciated since there are no instructions. thank u
93-97 firebird clear corner install
Re: 93-97 firebird clear corner install
If you've got skinny arms, put the headlights up manually and snake your arm in there, 3 screws hold them in place.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Originally posted by FunkZIf you've got skinny arms, put the headlights up manually and snake your arm in there, 3 screws hold them in place.---Niño---<br /><i>95\' silver 5 spd</i>
i think i'll try that before i take off the wind panel, however i imagine it would be difficult to replace the bulbs and but the screws back in , btw do you use the old screws to mount the new light? And my set came with oarnge lights, should i use these?
thanx for the help so far
max
the orange bulbs i got w/ mine didn't fit. i installed my corners from underneath w/o raising the front end. it took a lot longer than it needed to w/ limited space. its not hard to do, its just a process.94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
install is done fellas, did it all from above the car with my headlights in the up position, however my arms are shredded as there is little space to manuever. However they look good and it only took me 2 hours (not bad i suppose) thanx for all the help, and i used a 9/32 socket cuz i don't have metric =)
