heres a bit of a timeline..still not done but getting there...
Update on the damage
Tags: None
Re: Update on the damage
after some sanding and rubbing compound...
still have a lot of polishing and such to do..but i think it looks decent for a first time, using aerosol cans..
worst case, i get it painted..i'm pretty happy with the bodywork..so i just saved myself $650
EDIT: ~~~~UPDATE!!~~~
how's that for aerosol cans?Last edited by TheGr8Schlotzky; 07-02-2007, 12:37 AM.
Dude I hope you are kidding. That is an awesome job, I can't beleive it's your first time using that.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
nice work for 30 bucks man not bad at all for a first try<a href=\"http://photobucket.com/albums/a371/boyoi/firebird/?sc=1\" target=\"_blank\">My FireBird</a> K&N intake,Gutted cat, glass pack muffler.........Lots more to come...... <br />Getting my exhaust soon :)Rumbler Exhaust w/ Hooker\'s Headers :)
good job2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
i haven't taken to the bumper yet, and those spider cracks were there from some idiot a while back. I'm deciding whether to just replace the bumper or try and fix the whole thing. It pretty miuch fully needs to be repainted and there is a hole in in on the left side that my bumper sticker is currently covering up. It's something i could fix, but with bodyfiller in a plastic panel, what would normally just spider crack the area would also crack the filler, so i might just get a new back bumper.
The paint i used i believe was called PROMAX. Just an aerosol can from carquest, nothing special. Primed it with i think krylon autobody primer and clear was actually engine clear coat since they were out of the promax clear. it was the only other enamel they had, and it's friendly so it worked fine.
before painting, get the surface as smooth as possible.. i sanded to 1000 grit before spraying on my base coats. I got a few good coats of enamel black gloss and then wetsanded down with 1000 grit to get it real smooth and free of all orange peel. after that i used what was actually engine enamel clear coat. The biggest thing is to make sure you are using paint that is friendly with the base coat. i tried it with a lacquer base coat and it lifted and looked like sh!t.
For the clear, i pretty much put it on as thick as possible without running..but it did anyway, but i wasn't concerned about that because i could colorsand that out. So i sanded with 1000 grit between each coat of clear and i think there are 3 coats. after it was done, i colorsanded 1000, 1500, 2000, and 2500, then rubbing compound with a random orbital buffer (x3 or so), polishing compound (x2 or so), scratch remover, swirl remover, nu finish polish, and finally mothers cleaner wax. It really looked like crap until the swirl remover. that was meguiars and that is what REALLY works after the wetsanding. To be honest, this paint looks better than any other part of the car because it is just perfect. and imagine...aerosol cans..:)
haha, i'm not sure i'd go do a hole car with rattle cans, but i'm sure it could turn out if the time was put in to it. What really set this off was the colorsanding and swirl remover. If i had a whole ton of time, and this wasn't my daily driver, i might even consider repainting the whole car like this haha
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...2 weeks ago
