Light up front bird!! - FirebirdV6.com/CamaroV6.com Message Board
  • Light up front bird!!
    I just got a bunch of stuff for my car. I have a 99 navy blue metallic firebird. I am goin to try to make the front liscense plate insert bird light up. I bought a clear plate insert and am going to tape of with thin tape around each little design in the pheonix and have it painted to match my car. Then i bought leds that come in a pack of four with 6 ft of wire which i dnt know if 6 is enough but ill have to add more if its not. Ill put the lights behind the plate and run the remote into my car. I also got silver decals for the doors,front bird and rear where it says pontiac....any suggestions or feedback??
    Re: Light up front bird!!
    I'm not a fan of the lighting up of the bird, but to each his/her own. If you are going to do all that, then you might as well light up the side vents as well. And welcome to the board since I don't think I welcomed you
      ..you can light up the side vents?.......cool, I'd like to see that.
      <b>*97 Mystic Teal Metallic Camaro RS*</b><br />**Wyman**
        Search for it...or someone will chime in with a link
          Thanks and i think lighting up the side vents gets too ricey not saing the front isnt but thats gettn too much i think it lookss pretty cool im doin just the outside of bird though not wjole thing theres some pics at the linkhttp://www.ls1.com/forums/showthread.php?t=41341&highlight=light+front+bird
            I think somewhere someone just hooked up led's to their side vents that only blinked when the turn signal was on.
              alright i guess that wouldnt be so bad but still not a fan
              • Andy H
                Transmission removal help!!
                by Andy H
              • 2.8 Bird
                Abs inop
                by 2.8 Bird
              • fishin
                by fishin
