Console Removal - FirebirdV6.com/CamaroV6.com Message Board
Console Removal
  • Console Removal
    I need to repalce my console on my 2002 Camaro, but I can't get it out. I removed the 4 mounting bolts (front & rear) , but the console will not move. Any:dj: Suggestions?
    Re: Console Removal
    Open the lid, pull up on the coin tray. Remove the 2 screws. Pull up on the E-Brake handle and take a small screwdriver and lift the rachet dog (the little spring loaded thing that rides on the teeth) and hold it out so the handle will point strait up. lift up at the rear of the upper part of the console top and pull back. disconnect the wires for the lighter and the light for the ash tray. I think that is all but check to make sure. You must also remove the shift knob to remove the upper part of the console.
    <a href=\"http://members.cardomain.com/gmrulz2000\" target=\"_blank\">http://members.cardomain.com/gmrulz2000</a> <br />My 2000 V6 5 spd.K&N,Air silencer mod,TSP Rumbler, Magnaflow cat, 160stat.,H.P.P.III.
