project install system is finaly done :) - FirebirdV6.com/CamaroV6.com Message Board
  • project install system is finaly done :)
    i have 4 alpine type s speakers /w the dome tweater
    then i have...
    2channel kenwood amp power the 4 speakers (50w rms to each speaker)
    class D mono sub amp 500w rms 1000w peak
    alpine type r subwoofer
    all in a stealthy location
    i also dyna matted behind each speaker and most of the trunk
    and my t-tops still fit
    and with the flap up you cant even tell i have anything in the trunk.
    Re: project install system is finaly done :)
    nice, hows it sound?
      I was looking into a similar setup for my car about a month ago, but I realized that I'd rather go for performance instead of a sub. I have an Alpine head unit, and I was thinking of going with the 10" Type-R.
      I bet that setup sounds awesome! Good work!
        it sounds great and i love it. having an amp powring your speakers is a world of a difference. And you would be surprised at how much base that little stealth box makes
          did you build the stealth box or buy it?
          -Y87
          Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
            i bought it off ebay for about 50 bucks
              If I may, what is the exact model number of that sub you have there?
              Lounge Moderator
                not sure but it's the 10'' alpine type r dual 4 ohm
                  Wow, looks really good.
                  How do you remove the rear speaker grills? Do the just pop right out?
                    yeah they just come right out
                      why didnt you get a 4 chan amp for you speakers?
                      working on doing a similar install.
                      what did that sub cost you?
                      -Y87
                        because before i was using the 2 channel to power my sub, i went out and bought a mono amp to power the sub so i had the 2 channel left over for the speakers.
                        and the sub cost 200 bucks, but i think they are a little cheaper now
                          what about the front speaker grilles? don't you have to get behind the door panel for those?
                            yeah you have to take the whole door panel off for those
                              i got those componets too. i my doors n sails and they sound awesome with the stock monsoon amp. $ 55 a set. there gona sound sweet with the the added power.
                                6 days ago
