removing door panel - FirebirdV6.com/CamaroV6.com Message Board
removing door panel
  • removing door panel
    i searched some, but only come up with instructions for removing one off a 97. they are as follows
    Getting the door panel off isn't hard. There are 6 screws total:
    2 on the black portion of the panel where the door handle is
    3 on the door itself
    1 for the mirror
    Once you gets those screws out, lift the door up and it'll come off.
    Is this the same for a 98-02? im doing this because their is something inside the door that keeps scratching and tearing my tint. any idea on what it could be catching? the rips are occuring in the center of the window and from top to bottom. thanks for any help.
    Re: removing door panel
    yeah that will work for a 98-02 also.
    the thing that is scarching your tint is one of the little velt linning on the window brace has more than likly come off
