Shift boot ring - FirebirdV6.com/CamaroV6.com Message Board
Shift boot ring
  • Shift boot ring
    Anyone know if the boot ring for a 93-96 will work in the 97's? I'm talking about the ring that holds the boot to the console. I snapped mine while routing my nitrous wiring, and found one from a 95.
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
    Re: Shift boot ring
    they changed the interior in 97. so the console is different.
    WAWA-A-HOLIC
      Re: Shift boot ring
      OK. I too sure if maybe the kept the actual boot opening the same size and the same design so that maybe a 96 ring would work
      ~97 3.8L V6 Camaro~
      A few things
        Re: Shift boot ring
        PM Farmer2 at LS1TECH. I got a replacement from him for mine and love it. So much better than the POS plastic ring that came with the car.
        http://www.ls1tech.com/forums/showthread.php?t=426474
          Re: Shift boot ring
          i also bought one from that guy, one of the best 12 dollars i have ever spent
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
