As you can see i have gotten the roof taken care of. I also got the side rails off. Tomorrow I'm going to flatten and cut and fold the metal above the mounting areas. Any tips?? Help is always appreciated.
Progress so far
Progress so far
As you can see i have gotten the roof taken care of. I also got the side rails off. Tomorrow I'm going to flatten and cut and fold the metal above the mounting areas. Any tips?? Help is always appreciated.Tags: None
Re: Progress so far
invest in a spot weld cutter!!!!
it will save you a lot of time
and get a sheet over the interior of the car, you dont want metal shaving in your seat
Re: Progress so far
yeah i already got the spot welds out...took for freaking ever with a dremel...i swear i think i went through 20 cut off wheels. I also covered the interior. That was just a pic after the roof came off. Any pointers on good ways to line up and flatten the weatherstripping channel?
Re: Progress so far
yes, scor the part that you are going to bend with the cutoff wheel, then bend it and it will give you a nice clean bend. Use 2 pair of channel locks when bending. after you bend it slowly cut the piece that is standing up so that it is level with the rest of the channel. DO NOT OVERESTIMATE!! cut bits off at a time and then test fit the weatherstripping and t-top. You are going to want to test fit weather stripping and t-top several times!! What may look level or about right isn't necessarily true. Remember to leave room for teatherstripping in your channels. The back corners where the t-top molding meets the halo is very critical and unforgiving. (roof still intact) just remmeber take your time and know that there is not putting back metal, lol once its off its off.
Re: Progress so far
good (brave) work! keep us updated as progress continues.
Re: Progress so far
ur gunna love it... and when ur done check and double check and check again for any leaks... myne didnt seem liek it was leaking then we got a bad storm and my backseat foot area had liek 3 inchs of water in it...looks good so far though :tup:<a href=\"http://photobucket.com/albums/a371/boyoi/firebird/?sc=1\" target=\"_blank\">My FireBird</a> K&N intake,Gutted cat, glass pack muffler.........Lots more to come...... <br />Getting my exhaust soon :)Rumbler Exhaust w/ Hooker\'s Headers :)
Re: Progress so far
just remember cut less then you need to cut off... easier to trim later then cut again.
little late, b I used a circular saw with a metal black for th big cuts and trimmed with it, and a dremel.
I lucked out, I had a small sledge hammer that sort of fit the width of the channel. I put it in there and hammered another hammer to bend it up at a 90* angle.
X2 for sheet to collect metal shavings.
Personally I used a wood chisel and hammer to break the spot welds. Later we used a air hammer(moved to a gut with airtools house.)
Re: Progress so far
well i forgot to take pics, BUT i almost have one of the t tops fitted to perfection...one thing that seems odd, the weather stripping around the side of the window doesnt stick out from the car like my stock weather stripping did...tomorrow im gonna finish it up hopefully.
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...6 hours ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...2 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...2 weeks ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...2 weeks ago
by AZ3.8CamaroI have a 15 year boy now (crazy how time flies from when I was a teenager on here!) and his first car will be the old Camaro.
I stopped driving...3 weeks ago
