Hia all, I replaced the gear in the LH headlight motor with the brass type, and it was great for about eight months. Then the same old horrible sound returned. I had not used the other gear that was sent, so I put it in the LH and it lasted a few days before the gear slipping returned. The brass gear looked ok, so is the worm gear just too worn down to use anymore? I don't think the two gears were L/R marked, unless I missed it. (If so, may explain the second gears trouble.) I have almost convinced myself the worm gear is shot. If it is, I have never seen one available. Just the main gear, or the whole motor assy. Any input? Glad to see the sites still cool... Jessica
LH headlight motor worm gear
Re: LH headlight motor worm gear
Make sure the motor is still clamped tight to the gearbox - if it isn't the worm gear can deflect away from the main gear and start skipping.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
Originally posted by zlexissMake sure the motor is still clamped tight to the gearbox - if it isn't the worm gear can deflect away from the main gear and start skipping.
HokieBird! :) The powerdyne's got about 30,000 mi. on it since install. I sent it to Texas for new bearings when I got it, and they put the heavy duty ones I heard about in it. I see them on e-bay. I think the PD sealed bearings were good to 10K. I'm sold on these though. Not a lick of trouble from the setup at all, except for the famous loose belt syndrom. Car's a little worse for wear cuz it's lots more fun to drive with FI. I took some (long) time away from the internet, so I could win a bet with my mom. Getting a TA/hood with the cash. Hee. Not alot to do on a PC with no internet. How U been?Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
Good to hear you are still running the powerdyne! I don't even have a f-body anymore. I sold the firebird and got a subaru (mmm awd turbo). The bird was giving me problems and I got tired of driving it through snow. I miss it, but oh well.
Get some pictures when you put on the new hood and don't be shy about posting more often now that your bet is over.
BTW, if you need a replacement I found good prices at rockauto.comDrivetrain Moderator - "There are no stupid questions, only stupid people!"
Go Sabres!
umm ebay does have plastic ones. I'd still say spend the extra cash so that they dont fail on you in 2-3 weeks like mine did :(
http://cgi.ebay.com/ebaymotors/91-04...spagenameZWDVWCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
I recommend the brass too. My problem is/was a sloppy worm gear. If you are strapped for cash, I will send a brass one that is undamaged I found I forgot I had. PM me.Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
