yea, they look pretty good... also... isn't 16 in stock? that way you don't have to reset your speedo
You dont HAVE to reset the speedo if you buy tires that have the right aspect ratio. IE stock size is 245/50/16. If you wanted 17 inch rims you knock 10 off the aspect ratio. Then it would be 245/40/17. Same goes for 18s.. 245/30/18.. Lower the aspect ratio usually means higher the price of the tire. Just a FYI.
1995 Patriot Red T-Topped Z28 A4<br /><br />Mystery rebuild in progress.<br /><br />Soon to have 383 ways to beat KBreezy and Shane. :D
