Cleaning Under the Hood - FirebirdV6.com/CamaroV6.com Message Board
  • Cleaning Under the Hood
    My friend is a idiot and said just take a pressure washer and spray it.
    But wouldnt that mess things up electrical things.
    such as alternator and what not?
    What do i need to do to clean the underside of my hood with a pressure washer.
    i have this stuff its diluted acid, eats brake dust off like no ones business, i want to use it under the hood.
    what should i cover?
    Mods:
    Slp Dual Cold Air Intake
    Racing Stripes
    Flowmaster Exhaust [2.5 Pipes, Flowmaster 80 Series Muffler]
    Camaro Fill Ins
    Black Outs
    Tint
    Re: Cleaning Under the Hood
    i am not comfortable with the pressure washer under the hood. i tape off anything electrical when i wash it (low pressure with a hose after using some degreaser).
    I prefer the degreaser and a rag method myself. It takes a while longer, but does a better job.
    Visit My F-Body Page
      yea, i'd do it this way myself.
      '95 3.8L A4 PGM. & '95 LT1 M6 PGM. :burn:
        my method for all my cars since day one.....pop the hood, prop hood up, turn on hose, spray the sh!t out of it, add cleaner(nuwave), let it sit for a couple mins, spray the sh!t out of it again, towel dry! then i can floss my teeth in the shinny glow!
        WAWA-A-HOLIC
          doesn't ever mess anything up?
            I do the same thing.
            just dont spray directly onto the electrical stuff
            -Y87
            Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
              Or cover the alternator and coil pack with some plastic bags and duct tape.
                Spray away...
                I just take it easy around fuse boxes and around the PCM.
                Just spray and let dry for a few before driving. The only concern is the acessory belt slipping because of wet componets.
                  ive used a pressure washer as well. the only way some of the electrical stuff will get damaged is it you try and use it while its wet, or if the water sits too long it can begin to rust. just make sure everythings dry when youre done and you will be ok :)
                  Dave:
                  00 Supercharged Camaro - RIP
                  97 Turbo Camaro - Sold
                    Ehhhh Dave! I just realized who you were...whatever happened with the citation?
                    Oh if you don't remember I hit your webpage a few months ago and we emailed a few times...that's when I found out you wrecked your ride. Sorry again...
