Hey after u guys installed the SS spoiler did u have a problem with ur abs light comin on after? just wonderin cuz thats what has happend with mine...heres a link that tells me how to fix it but im always lost when it comes to elec skymatics http://shbox.com/1/relay_for_ss_spoiler.jpg can any1 tell me what exactly its tellin me?
SS Spoiler install
Re: SS Spoiler install
i know this thread is old but can anyone help me with this problem. im about to order an ss spoiler and dont wanna run into problems when im installing it. what wires do i put a resistor between and what kind of resistor (sry i dont know much about wiring). or could i install it and take it to a shop to do it or is it that easy....? thanks guys
-kyle
prior to the connector? does a aftermarket ss spoiler that comes withthe brake light have the connector and just connects right up like stock? also prior as in the spoiler side or the side connects to car(if that makes since)? sweet take some pics if you can. i keep getting lost about this whole issue
Originally posted by kylerobison View Postwhere can i get one of those at? so i see you just connect a wire between the 2 wires leading to the brake light and then in that wire tap just add in the resistor?
nevermind, I read the shobox diag. different resistance with the leds... thats crazy... thanks for someone bumping this one up, I would of freaked out when I installed my SS next week.
ArcherMISC: 01 parts. Some interior, T top kit, seats etc.
http://forum.camarov6.com/showthread.php?t=95347
Originally posted by whiteThunder View Postso what do you put around the resistor to protect it and make sure that it doesn't short out? Would a relay like the one shown in the diagram be a better option?
FYI guys: This does NOT apply to everyone. My SS spoiler does NOT need the resistor, my ABS light stays off without it. However, right now I have my stock spoiler on with plug in LED lights, which DO need the resistor, which is why I could take that picture. It depends on what the configuration of the light bar is in your spoiler.
There's nothing wrong with preventative maintenance. The way to test would be to measure the resistance across the circuit and compare to the threshold in the cars wiring that would trigger the light. Unfortunately I don't know that number, so it's mostly a matter of whether or not the light comes on.
