SS Spoiler install - FirebirdV6.com/CamaroV6.com Message Board
SS Spoiler install
  • SS Spoiler install
    Hey after u guys installed the SS spoiler did u have a problem with ur abs light comin on after? just wonderin cuz thats what has happend with mine...heres a link that tells me how to fix it but im always lost when it comes to elec skymatics http://shbox.com/1/relay_for_ss_spoiler.jpg can any1 tell me what exactly its tellin me?
    87 Firebird RIP
    96 Camaro RS RIP
    94 Patriot Red 1LE Z28 - Sold
    02 WS6 TA - Sold
    Re: SS Spoiler install
    Just put the resistor between the two wires coming out of the spoiler :
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      i know this thread is old but can anyone help me with this problem. im about to order an ss spoiler and dont wanna run into problems when im installing it. what wires do i put a resistor between and what kind of resistor (sry i dont know much about wiring). or could i install it and take it to a shop to do it or is it that easy....? thanks guys
      -kyle
        You splice the wires prior to the connector and run a resistor from the black to the red. Don't cut the wires, just add in the resistor. I can get you the rating on the resistor when I look tomorrow.
          prior to the connector? does a aftermarket ss spoiler that comes withthe brake light have the connector and just connects right up like stock? also prior as in the spoiler side or the side connects to car(if that makes since)? sweet take some pics if you can. i keep getting lost about this whole issue
            Eh, I've got nothing better to do.
            I've got a 25W, 27ohm resistor.
              where can i get one of those at? so i see you just connect a wire between the 2 wires leading to the brake light and then in that wire tap just add in the resistor?
                Yes. I got it at a local small electronics store. Radio shack or similar should carry them.
                  so what do you put around the resistor to protect it and make sure that it doesn't short out? Would a relay like the one shown in the diagram be a better option?
                    nevermind, I read the shobox diag. different resistance with the leds... thats crazy... thanks for someone bumping this one up, I would of freaked out when I installed my SS next week.
                    Archer
                    MISC: 01 parts. Some interior, T top kit, seats etc.
                    http://forum.camarov6.com/showthread.php?t=95347
                      Electrical tape will be fine.
                      FYI guys: This does NOT apply to everyone. My SS spoiler does NOT need the resistor, my ABS light stays off without it. However, right now I have my stock spoiler on with plug in LED lights, which DO need the resistor, which is why I could take that picture. It depends on what the configuration of the light bar is in your spoiler.
                        well right now I have a wings west ss spoiler with led bar. I didn't notice if my light went on as a result of the install, but want to do this anyways to make sure that the abs doesn't act up as a result.... sound ok to you? How will i know if i need it
                          There's nothing wrong with preventative maintenance. The way to test would be to measure the resistance across the circuit and compare to the threshold in the cars wiring that would trigger the light. Unfortunately I don't know that number, so it's mostly a matter of whether or not the light comes on.
                            Preventative is the way I roll. Anyways, right now the light is on. The light has always been intermitent, so I never know. I think that I will go ahead and install it. What do you recomend for covering the resistor? Tape?
                              check post 11
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
