ok so i have been getting ready to do my t-top conversion. im going off this write up http://members.fortunecity.com/gripe...onversion.html
i dont understand the pop rivit part. can some one explain or is there another
write up out there??
because in the corners, there is nothing there, your going to have to bend some metal for the weather striping to hang on to. i just bent it up, and bondo everything to make it look stock.
ok i understand now. why would you pop rivit it then? is it hard to use bondo i never used it b4
bondo is easy to use. Just make sure the part your doing is paint free and clean. Just add some hardener (follow directions, it's like 1/20th the amount of filler your hardening) then mix it up good on piece of cardboard or something and apply it trying to fill all the holes and stuff. Don't be afriad to use way too much, because the stuff sands down really quick with 80 grit. Work up to 400, prime, 800, base, base, 1000, clear, clear, or whatever your going to do.
I've never really been all that keen on t-tops so this little mod won't be in my cars future (at least not while I own it). Even if I did like t-tops, I wouldn't have the balls to try this myself.
bondo is easly just takes time, i did it over a 5 day period. i would bondo, let it sit, then wet sand. wait a day, do the same thing until it was flawless. then a day with a few rattle cans and BAM t tops
I would be WWAAAAYYY too afraid of screwing something up. Overall, is this an easy modification or is it really complicated?
1998 Chevrolet Camaro SS New Trans Setup:Rebuilt 4L60E, Yank ST2800 Stall, B&M Trans Cooler,
TCI Deep Pan, Royal Purple, Trans-go Shift Kit. Should be done in January.
So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...
