just got my new driverside fender painted in the mail, great color match, does anyone know hot to replace it? like step by step? thanks in advance...
need help with a fender...
#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>Tags: None
Re: need help with a fender...
I know you'll need to take off your splash guard in front of the wheel well, as well as the one that goes around the wheel. Those are pretty easy and self explanatory to get off. The front gaurd is 10mm bolts, and the inner wheelwell one is a couple 7mm bolts. Once you have the front guard off, there is a piece of metal with three bolts in it. (i believe 13mm but not positive) It attaches the front bumper to the fender, so take those three out and the bracket will come out and get that part disconnected.
There are two bolts on the underside of the fender in back of the wheel under the car..
Open the hood, and there are a series of bolts on the fender in there as well.
Then I believe there are a few more bolts that will be accessed from inside the wheel well once the splash guard is off.
Shouldn't be too bad, but there are plenty of bolts holding it on.Last edited by TheGr8Schlotzky; 01-21-2008, 10:19 PM.
hey thanks for replying. ill post up when I do it this weekend.#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...4 weeks ago
