I shred of hope for T-top? - FirebirdV6.com/CamaroV6.com Message Board
  • I shred of hope for T-top?
    For all of you who have done T-top conversions. What would you rate the difficulty level of the whole process? Point being do you think three 18 year old, with very little to no experience, kids could pull it off with internet guides?
    Car is a 1995 camaro.
    Re: I shred of hope for T-top?
    It is something you really need to take your time with. As long as you do your homework and have the cash flow - by all means go for it. Just, for something like that, you really gotta be sure your gonna be able to do it because its not reversible if you make a mistake(at least not for cheap). Sorry, don't mean to scare you, just being honest :)
      I had no idea that you could even do T-top to a typical hardtop model.
      How much and where to buy.
        i would give it like a 5 or 6. not too hard and you need to have a knowledge of basic hand tools.
        96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
          agreed 5 or 6. Hell i was 18 wehn i did mine and i didnt have any help and all the wrong tools
            I am going to say mine was a 5-6.
            the important thing is, cut less. take your time, you will run into the big problems if you cut too much.
            other then that its not so bad, all you really are doing it cutting, very little bondo.
              you know what they say, "measure twice, cut once"
                i'm 23 and did mine bymself.. i took my laptop outside and read and looked that the pictures over and over. i've never did anything like that.
                i can take pictures of mine off if u wanted to see more pics of where to cut the metal bars at. cutting the fiberglass roof off was easy. u gotta use a dremel with a cut off wheel though i believe. then a electric saw to cut the 2 metal bars. the hardest part is cutting the weld spots out on the bottom of the roof (one of the last steps)..
                ttops are usually a 100 each on ebay. i got mine for 100 for both from someone on craigslist locally. then bought the rest of the stuff off ebay. weather stripping, lock brackets, center bar, a-pillars, b-pillars
                  Hmmm i think I'm going to go for it. Sometime in the spring, I dont see the point of doing it in the winter lol. Thanks for the boost of confidence.
                    i didnt measure anything but how much mixing of crown i was doin. it defianately helps to have a good buzz, well me anyway.
                      where you located at bear
                        i cut my roof in my front yard.. i wanted all the neighbors to see me and hear me. i wanted them to know i put t-tops on the car myself. alot of people drove by staring at me
                          it's easy. just takes time. i would say 7.
                          WAWA-A-HOLIC
                            About two miles north of Toledo, Ohio. Large suburb in south east Michigan. Monroe County.
                              im only 17 and did it by myself with the help from ppl here
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
