i think they turned out ok for what i put into them. Wasnt looking for some hard core port job.
Self ported/polished heads and intakes
Re: Self ported/polished heads and intakes
Looks good, wrong section Newb. J/K08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
This is basically what i started with.
Thisis the other head i have only done the intake port on
Thats what mine looked liked when I started, the heads will look alot better when their milled, and painted.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Are you going with the stock SI valves?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
either those, or i might go with manley valves. I heard there were some problems with si valves failing?
Originally posted by Meatyshells View Posteither those, or i might go with manley valves. I heard there were some problems with si valves failing?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
i will be fine, i didnt "hog out" the ports, i just cleaned them up by removing casting flaws and smoothing transitions
You'll be fine, I did this 5 years ago when my engine was rebuilt and never had any problems. And that is after running a supercharger and now running 125 shot of nitrous. It is when you start reshaping and start expanding the ports and taking alot of material off is where you run into problems, since you have to make them the same.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by HossV6 View Postyou want your intake ports to be ruff, and exhaust to be smooth. you might want to ruffen up the intake ports a bit. just something i learned back when i used to build quads..
Did you use the standard abrasive porting kit?
I have the deluxe porting kit, die grinder, heads, and the intakes are on their way.. I'm going to start mine tomorrow.
I don't have the intake gaskets yet.. what should I do tomorrow? Just like, take out the casting lines/start the valve guide/smooth short side radius?
I stopped driving...2 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...4 weeks ago
