Would these fit my car? - FirebirdV6.com/CamaroV6.com Message Board
  • Would these fit my car?
    From a GTO?
    2001 Firebird 3.8L
    Re: Would these fit my car?
    Whats the offset and bolt pattern?
      Bolt Pattern: 5 x 4.72 or 5 x 120
      Offset: 35
      2001 Firebird 3.8L
        No...they will rub. Offset needs to be in the 50 range. 56mm specifically.
          Ok thanks, so much for that.
          2001 Firebird 3.8L
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
