Common Problems? - FirebirdV6.com/CamaroV6.com Message Board
Common Problems?
  • Common Problems?
    I still pretty new to f-bodies and cars in general and was wondering about the common problems asociated with my car. So far I've heard:
    -cracking around the circular air ducts
    -cracking door panels
    -teeth on the plastic headlight gears braking
    -weak/dying power windows
    -rusting door hinges
    -interior squeecking
    Are these right? Is there anything else? Do you guys experience any of these or others?
    So far my car is afflicted by the cracked air ducts, cracked door panels,rust on door hinges, the squeecking (sounds like it's coming from inside the door and somewhere behind the driver), and my window motor vibrates the whole door on my passenger side and my driver side motor only works about 98% of the time.
    Re: Common Problems?
    there's a lot of "smal" problems with these cars. they for 1 have cheaply made, plastic interiors, and are known for numerous problems. they throw coilpacks like crazy, go through o2 sensors like crazy, suck alot of gas, yes even the v6's...and the turn signals in front tend to burn up really really fast, so I bought leds...but yeah, they're pretty cheaply made. But I love mine! :-)
    #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
      love me my manual windows!
      But that list is pretty complete. My stick tends to jump out of second gear on cold mornings I hear thats pretty common.
        Already a long thread like this in the sticky of gen tech.
        http://www.forum.camarov6.com/showthread.php?t=9382
        1996 Chevrolet Camaro
        1995 Buick Park Avenue Ultra
        --Appearance Moderator--
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
