I just bought some stock wheels off a 2007 Corvette, sizes are 18x8.5 and 19x10. Will these wheels fit on my 2000 Firebird without having to use spacers? I don't have any tires for the wheels yet so what size should I go with?
C6 wheels
C6 wheels
<a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ftTags: None
Re: C6 wheels
fronts fit without any problems at all. go with 245/40/18.
rears will require at least 1/8 worth of spacer. im not sure exactly how the wheel well on an 00 bird is shaped, but my 94 camaro needed some "massaging". 285/35/19s fit very nice. any wider on the tire youll need more spacer and anything more than 7/32 worth requires longer studs.
i just went through all this.
foggy headlights? wetsand... buff... WAX!!!
if nissan motorsports is nismo does that mean honda motorsports is homo?
Re: C6 wheels
Originally posted by 00FlowCamaro View Postthose wheels dont really thrill mefoggy headlights? wetsand... buff... WAX!!!
Re: C6 wheels
Originally posted by CamaroJeff™ View Postso dont buy them or put them on your car. i didnt put those wheels on my car hoping everyone else would approve, i got them because i like them. im sure Fred dosent care wether or not they thrill you either.
Re: C6 wheels
Thanks for the info, CamaroJeff your car looks great with those wheels! Those are 2008 wheels right?<a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
Re: C6 wheels
yep, theyre the 08 "indy pace car" wheels. same sizes as yours, although i originally thought they were 19x11s in the back, theyre 19x10s.
if you want a truly "no scrub" fit youre going to need to use spacers and probably longer studs for the back. mine are set up with 7/32" spacers (thickest you can safely use without longer studs) and on a hard bounce or body roll you do hear them kiss the inner fender slightly.
youll also have to jack the entire rear end up to get them on, otherwise the inner lip of the wheel will hang up on the bounce limiter... or whatever you want to call it. regardless you really shouldnt put them on one at a time with the rears.foggy headlights? wetsand... buff... WAX!!!
Re: C6 wheels
Originally posted by deftons56 View PostI put some 2005 c6 rims on my car and didnt need spacers in the front but I put 1" spacers on all 4 and it looks 100xs better. Now they fill up the entire wheel well and arent all sunk in.foggy headlights? wetsand... buff... WAX!!!
Re: C6 wheels
Originally posted by deftons56 View Postoh, I see. Still, if you "don't need them" but could use them to get the wheel out to the wheel well, do it. Looks way better and totaly worth the money IMO.
depends on how much work youre willing to go through to get a set of wheels to stick out more, not so much the money. 1" spacers are more like adapters which imho are very unsafe. im not sure just how thick you can go with a solid spacer but anything over 7/32" gets into the "very little thread on the lug nut" territory and requires longer studs. longer studs require pulling the axles for the rears.foggy headlights? wetsand... buff... WAX!!!
