24 watt led's question...please help. - FirebirdV6.com/CamaroV6.com Message Board
  • 24 watt led's question...please help.
    ok I bought these hyperwhite leds for my marker light/turnsignals and i put them on, they're bright as hell, but they don't blink for some reason and ive heard that its cuz its such a low wattage it tricks the car into thinking there is a burnt bulb. so I don't know what to do. How can I make it blink with my blinker? thanks.
    #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
    Re: 24 watt led's question...please help.
    You need an electronic flasher unit.
    And I assume you mean 24 LED bulb. There is certainly no LED cluster bulb that takes 24 watts.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      this is the bulb I bought....it says 24w on the package...and it doesn't blink. what exactly is an electronic flasher? where can I get it? help me schlotzky...im a fellow oregonian!
      http://cgi.ebay.com/ebaymotors/ws/eB...199236340&rd=1
        I think that's just a model number, pointing out that it has 24 LEDs and is white.
        Basically how a flasher works, is there is a little piece of metal that heats up when the bulb is activated, and cuts the power when it gets too hot. When it cools down it repeats the process. LEDs don't draw enough current to make the strip of metal get hot, so they don't always blink. Electronic ones do this on a circuit board instead, so load doesn't matter.
        I'll see if I can find one that is for sure compatible.
          thanks dude, you seem to be pretty damn helpful on this board, which is why I haven't gone to the ss board because I feel like you v6'ers are my family. hehe
            It looks like there really isn't any special models for electronic flashers, just 2 and 3 prong. I replaced my flasher unit a while back and I remember it had 3 prongs, so something like this should work out for ya.
            http://cgi.ebay.com/ebaymotors/New-N...3286.m20.l1116
            Yeah, it does seem like the v6 community is more of a family, doesn't it? lol
              You might check out local autopart stores as well for the electronic flasher. Autozone and the like would normally have them in stock and that would probably be quicker and easier than ordering online.
                Yours had 3 prongs? That's weird. Both my turn signal and hazard flasher relays were only 2 prongs.
                <b>1995 Pontiac Firebird</b> || 3.4L V6
                  I could've sworn it had 3 prongs. I guess I better go check it out.
                    well did it have 3 prongs? and where is the flasher located?
                      Under the dash, pretty close in line with the steering wheel. It's a silver canister looking thing. Approx 3/4" to 1" tall.
                      '99 Mountaineer AWD 5.0 - 4300K HID, Some Bolt-ons
                      '97 RS - HPTuner, Bolt-ons
                      '09 WRX - Aesthetic mods
                        what part of the dash do you remove? the whole piece under the steering rack?
                          Yup..
                          Like what was already said, just look for the silver canisters.
                            and can I get one of these e;ectronic flashers at autozone? are you sure it'll work? what makes them work and the ones we have not work? thanks
                              You should be able to find one at autozone and the like, I've seen them. I haven't had a chance to get in my dash but from that pic, it looks like there is just the two wires going to it, so it very well may have been 2 prong. It was a while ago that I replaced it so it's a little fuzzy.
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
