how to prep for paint? - FirebirdV6.com/CamaroV6.com Message Board
  • how to prep for paint?
    well i decide im going to take my car to maaco but im going to do all the prep work myself. how should go about doing this.
    Re: how to prep for paint?
    what condition is the car's paint in right now? i reccomned going over everything with 600 grit sandpaper and making sure its nice and smooth everywhere, dont worry about the color or scratches etc.. my rule of thumb is.. if you can physically feel it.. you will SEE it once the car is painted. AKA a blind man can prep a car the best!
    Dave:
    00 Supercharged Camaro - RIP
    97 Turbo Camaro - Sold
      well the guy b4 painted it in his driveway and didnt do it very well. so it look like crap. and i just put a trans am front bumper and rear hatch. so it not that good. should i take everything down to metal? and what about the door they are fiber glass right can i sand that? should i primer the car?
        if i were you, i wouldnt take it down to the metal unless you absolutely have to (remember though, the only thing really metal that you will have to worry too much about is the rear quarter panels and hood. pretty much everything else is fiberglass or plastic and yes you can sand it. i would sand everything with 600 like i said, to make it smooth, and primer it if youd like, but its gunna take at least 5-6 cans of primer.. i wouldnt bother, especially with a maaco job. but its up to you.
        Dave:
          ok thanks alot
          o should i wet sand at all?
            600 grit paper is preferred; generally dry sanded for prep. Use a catalyzed primer; do not use spray cans. Also, poly parts should be primed with a special primer for plastics. Prep it until the surface is perfect. If you paint dog crap, you'll just have different colored dog crap.
            Lounge Moderator
              whats canalized primer?
                Sorry... Meant catalyzed.
                It's a two part primer. The primer and the hardener (catalyst) are mixed then sprayed.
                Lounge Moderator
                  o ok and where can i get that?
                    Any auto paint supplier. You'll need an air compressor and a paint gun though. Are you close to Atlanta?
                    Lounge Moderator
                      san diego. but i have air compressor and i saw a paint gun at wal mart for 30 bucks so ill get that
                        Yup yup... $30 HVLP gun at Walmart will work fine for primer. Hopefully it'll have a pretty big tip on it; 1.0 to 1.4. Sand that bad boy down hard. Get an uber course grit paint to knock it down faster. Shoot some heavy coats of a good filling primer. Block it down with 600 grit and you are gravy.
                        Lounge Moderator
                          This one?
                          http://www.walmart.com/catalog/produ...uct_id=9189097
                          Lounge Moderator
                            If you have many chips and deep scratches, you'll be better off starting with 220 and getting it absolutely smooth, then stepping up to 600. But the given information is good otherwise.
                            1996 Chevrolet Camaro
                            1995 Buick Park Avenue Ultra
                            --Appearance Moderator--
                              THANK YOU!!!. lol
                              Even though his paint job came out well with rattle can primer... most primers arnt compatible with auto paint... it will bubble, chip, peel, or have a bad chemical reaction. lol
                              If you need any more detailed info you can ask me, or a couple other guys have painted their cars.. I custom paint sportbikes on the side.. Just remember it can get pricey, DONT RUSH IT.. take your time, you'll be fine. Painting a car isnt as hard as people make it out to be.
                              maco can paint cars. but remember you get what you pay for. you go cheap stick with the color you have and plan on buffing it afterwords, pay a lil more and they'll do a good job. if your scared with the prep and mix of paint... go to your local body shop, see if they have extra paint they have to get rid of. remember they PAY to get rid of it, so most of the time they will just give it to you. Go to local junk yrd and get a fender and use that to practice. the best paint jobs come from practicing and PREP.. ventilated area, clean, no dust.
                              also, if you paint, put a chain on the control arm and let it touch the ground. this helps with static electricity. its a ground. all that paint and air flying around will cause a static electric charge and things WILL STICK. plastic is the worse for doing this..
                              i use a 1.4 for my 2 stage paint, and a 1.7 for my primer. I build high and sand smooth then seal.
                              have a water remover (have a couple of them) also known as an air dryer. and a face mask, because believe it or not, I had a friend (after some years of painting) he lost his hearing because of it. its nasty ****, you dont want to breath it in. a doc paper mas WILL NOT DO>....
                              anything else just ask
                              Archer
                              MISC: 01 parts. Some interior, T top kit, seats etc.
                              http://forum.camarov6.com/showthread.php?t=95347
