how did you mount the side skirts? I have a camaro and I have the rs body kit I want to put on it, when I took the kit off my rs to put on my ss, the rs had some frikken sheet metal things with rivets in them, so i dunno...how did you do yours? Im hoping to do mine next weekend
#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
my side skirts are used and warped.
they're attached with 1 screw on the front fender and back area then the rest is double sided tape. the tape holds good. you can really tell that they're warped now.
i'll find a way to fix the side thats still warped.
unvmyrs. just take the rivets off of the rs side skirts i guess. then use double sided tape and screws on the fender area. no need for all of those rivets. my 97 mustang was the same way. probably 50 rivets on each side. crazy
