94 gauge cluster in 96? - FirebirdV6.com/CamaroV6.com Message Board
  • 94 gauge cluster in 96?
    okay....so not long ago i swapped to a lt-1 and want the 155mph gauges to go with it. i have found a cluster from a 94 with pretty much the exact mileage the new setup has on it...so i want it. i was just wanting to see if it was compatible because the 94 cars were obd1 and 96 went obd2....so anyone have any advice? also...if it will work, but only if done a particular way (the resistor or the tune, ect) please specify.
    thanks
    - trey
    96 polo green RS w/ some extra stuff<br /><br />15.4 @ 89
    Re: 94 gauge cluster in 96?
    they should be compatible, but i know for sure your RPM is going to be off
      if hes swapped in a LT1 why would his tach be off if he uses a v8 cluster? im sure its off now with a v6 cluster reading off a v8. the main question i have is, are the pin connectors different from the 94 to the 96?
      1997 3.8 5-speed Camaro<br />BMR STB, LCA\'s, SFC\'s,Panhard bar, Torque arm,1LE sway bars<br />Headers, SLP cold air, Flowmaster catback, takeoff LSD, Eibach pro springs<br />Hurst shifter, 01 Z28 guage cluster w/ white face overlays, billet grill w
        thats fine with me...it needs to be tuned anyways
        ...as for the pin connectors....anyone know????
