Please help be fix this - FirebirdV6.com/CamaroV6.com Message Board
  • Please help be fix this
    every time i close my drivers door this happens has anyone else had this and how can i fix it easily
    Re: Please help be fix this
    its just gotta be popped back in. roll your window down all the way and look inside the door where that black weather stripping attaches itself to the side of the inside of the door where those little clips are and pop them back into place.
    Dave:
    00 Supercharged Camaro - RIP
    97 Turbo Camaro - Sold
      will the clips snap back easy or do i need to bend them
        mine did that all the time too, i always rolled my windows down and popped it back in like dmw said, but it NEVER stays.
        *Matt
          who ever owned the car before me must have always pushed the windows to shut the doors
          i'm thinking of taking the interior panel off and seeing what i can do
            had that happen to me....except when mine came up and i tried to push it back down it wouldn't stay, i looked closer and the last two clips on the stripping were broken, nothing you can do then except buy more stripping because i tried everything to keep it down and nothing worked....so check and see if those clips are broken, if not you should just be able to pop it back on....otherwise its new stripping time.
              This happens to mine all the time. I thought I fixed it a few months ago because it hadn't happened for 2 months. Then yesterday we went shopping and when I shut the door it popped up. I bent the pieces so that way it would stay in better, it has helped to make it stay in for a longer period of time, but it will eventually pull back out.
              Welcome future UK stars... Darius Miller, Deandre Liggins, Kevin Galloway, Josh Harrellson
                i was just outside and had the interior panel off and i managed to get three of the clips at the end of the door back into there place none of the others are broken but i was running out of light heres the quick fix pic
                  oh yeah i was also able to fix my rattling window problem on that side, when i do the passenger side i will take some pics and write up a good description on how to fix that incase no one has yet
                    sounds good. often times those little clips break and you gotta replace them or else that window stripping wont stay in right.
                    Dave:
                      The hardest part is getting them back in all the way... mine did this all the time, especially if I would open and close the door after it'd been sitting in the sun for a while. I'd push it back in but it wouldn't stay... then when I was replacing the window motor I pushed it back in but with the inside panel off and could see the clips weren't all the way in... gave it a good tap all the way across and it's stayed in so far
                      Custom interior...
                      TEAM NoVa
