T-top questions (searched) - FirebirdV6.com/CamaroV6.com Message Board
  • T-top questions (searched)
    Ok so I did a search and I am surprised nothing is stickied on these things yet...anyways I saw that a lot of people did this mod themselves and it looks good...I dont want to touch it myself though, so I was wondering who had the t-tops professionally installed and how much did it cost you?...what kind of shops would do something like this?...and for those of you who had it professionaly installed did you end up having any leaks?
    most of the info I found was ppl doing it themselves and doesnt really answer these questions...
    Thanks guys/gals.
    Also if I have searched correctly I believe I need A pillars, B pillars, t-tops, some middle bracket, and I believe some clips, and chop my headliner correct?
    Re: T-top questions (searched)
    I dont know of anyone on here that had it professionally done. Might try finding someone near you that has done it to help you out with it if you choose to do it yourself.
    2000 v6 a4 Camaro
      no one has had it professionally done. Do it yourself or not at all
        ^^ agreed. I can't imagine how much a shop would charge, but surely way more than it's worth.
        Check out the regionals, see if there is someone local who will give you a hand.
        1996 Chevrolet Camaro
        1995 Buick Park Avenue Ultra
        --Appearance Moderator--
          There is no Canadian Regional Section :stp:
            i did it by myself like 2 and a half years ago, back when there was only a hand full of people who knew what they were doing. now everyone seems to be jumping on the band wagon seeing how easy it is lol
              i know someone out west who was looking for a shop to do it. but no one would touch it with a ten foot pole
              WAWA-A-HOLIC
                how many of you guys chopped your headliners?...can you tell its chopped? or are you better off just buying a headliner for a T top car?
                  i got a t top headliner. there was no way that i was going to put a cut up thing in my camaro. just the way i am
                  WAWA-A-HOLIC
                    kristen how hard was it to put on?
                      there is the 3 bolts with each sun visors, 1 plastic pusher in the middle of the head liner, 2 bolts that hold the rear light in. then you have to put the a pillars back on, and the rear plastic panels back on too.(where the hanger hooks are)
                      WAWA-A-HOLIC
                        are those (a pillar and back plastic) just clipped on? I was trying to take them off awhile ago and couldnt figure it out....
                          ^^yes just pull the a-pillars towards the outside of the car. and the back panels are just really strong velcro
                          1997 Camaro LS1 RS
                          1994 Camaro - Sold
                          1999 Trans am Vert - Sold
                          A Few Mods....
                            fronts just have 3 clips on the inside. just pull those off. then the rear, take a flat head screw driver and you pry out the bottom of the hanger hooks. then they pop off. you can move them out of the way enough. you might have to take the floor piece off if you don't have enough room. which is only 4 screw on the pass side and 5 on the drivers
                            WAWA-A-HOLIC
                              T-top headliner is modifiable if you know what you're doing. With enough effort it could look just fine. The only thing is that the A-pillar won't line up correctly with the headliner in the front because of hte dip in the hardtop liner for the sun visors.
