i need the molding delete - FirebirdV6.com/CamaroV6.com Message Board
  • i need the molding delete
    heres the pic what you think
    Re: i need the molding delete
    "Image or video has been moved or deleted"
    Rick
      Now it works. Odd
      Rick
        I like the trim/molding. It helps break up the side of the car. The previous owner of my red firebird painted the molding and the word "firebird" black on one side of the car. No idea why he only did one side, but I like it better painted too for contrast.
        Rick
          looks A LOT better without it. good job.
          2002 SOM Camaro- Sold
          2006 S60- Sold
          2000 Cherokee- The desert whip
            i did the molding delete
            another pic
              much cleaner
                Looks cleaner, lose the pinstripe.
                Y87 Package
                MOGOB APPROVED!
                BONE APPROVED!
                VANBIBBER APPROVED!
                KRISTEN APPROVED!
                Vice Prez.
                Team Black...TEAM EMO
                Come on kids! Get a Calendar!
                  How do you do that? I've been wanting to do that on mine for a while.
                  To the OP: Looks great man, I like that you kept the "Firebird" emblem on the doors.
                    I have heard of two way to do this. Both require alot of patience and it's relatively easy to do, but easy to F*** up if you're not careful. But anyone that can wax or apply a decal can do it.
                    I do it this way, unless it's absolutely unreasonable.
                    Best way IMO is to get a hair dryer (do NOT use a heatgun), and mildly heat the area of the pinstripe. By only using a hair dryer, the most you will ever get the area to is ~250* F. This won't hurt the paint, but is hot enough to soften the adhesive on the pinstriping. I recommend shooting for a temp of around 180* F. Then using a PLASTIC razor blade (please for the sake of all of us do not use a metal one) carefully "scratch" away the pinstripe. Hold the blade at about a 20* angle relative to the body panel. That way it's sharp enough to pull the decal, but shallow enough to where it won't gouge your paint. TAKE YOUR TIME. Once the pinstripe is gone the clearcoat might be "ghosted" a little bit, you'll need to buff that area with a fine cut paint cleaner, and then step up to swirl remover, polishing compound, and then follow it with a coat of wax. That SHOULD get rid of alot of the ghosting.
                    The rest of it will clear with time as the color of the paint from under the pinstripe fades to match the car.
                    The other way to do it is using a type of enamel reducer to soften the clear coat and a buffing motion to remove it. DO NOT TRY THIS UNLESS YOU HAVE FIRST-HAND EXPERIENCE WITH ENAMEL REDUCER AND ARE AN EXPERT ON AUTO DETAILING. If anyone has further interest in the second option, pm me for more info on it.
                    Good Luck!
                    Y87 Package
                    MOGOB APPROVED!
                    BONE APPROVED!
                    VANBIBBER APPROVED!
                    KRISTEN APPROVED!
                    Vice Prez.
                      looks great. its always risky taking it off though... never know whats underneath. look out for door dings.
                      Visit My F-Body Page
                        Did pinstripes come on some Camaros/Firebirds from the factory? Because I notice that a lot have them on.
                          yeah it was an option...im pretty sure.
                          Y87 Package
                          MOGOB APPROVED!
                          BONE APPROVED!
                          VANBIBBER APPROVED!
                          KRISTEN APPROVED!
                          Vice Prez.
                            I really like and and dislike it. i am indefferent about the side molding. I have the Same color as you w/o the pinstripe. I dont really know how to feel about the molding. its gotta be different in person... i want to do it, but then i dont want to...
                            could you possibly take some more angle pics if its no trouble?
                              Re: i did the molding delete
                              Originally posted by 98v6firebird View Post
                              another pic
                              what did you do to your turn signal housing here to get them clear like that?
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
