The window on the drivers Side is kinda tilted inward toward the front of the door next to the mirror. I took the inner panel off and tried to fix it but I don't know what to do. The window is power and also the door handle is starting to come off....does anybody know a simple way to fix these things?
My 94' Window
Re: My 94' Window
http://shbox.com/1/adj_window.html
Adding this to the appearance how to section as well.
Re: My 94' Window
If it's "loose" there may be a problem with the window track. There is a pivot joint that connects the window frame to the window track, it seems to be relatively common that the rivet holding the pivot to the window track will "slip" out, causing the window to be very loose. It requires removing the tracking pivot and tapping a new hole to add a bolt.. I had to do it on my drivers side, let me know if you need any more information.
Re: My 94' Window
i'm gonna guess the "tracking pivot" you speak of is that lil ball shaped thingy that rides along in the track, mounted at the bottom corner of the window...if so, that's exactly my problem, now that i think of it...when we had my panel off puttin my door back together, i noticed that little ball seemed to have broken off, and someone tack welded it back on...very crooked. as a result, the window moved in and out of the track very freely when going up and down, until we got some pressure back onto the window w/ the door. it's still very loose, and there's a lot of movement inboard and outboard. also, when i roll it up it goes noticeable further up that the passenger window, and theres a buttload of space between the window and the rearward seal, it also doesnt butt up under the t-top seal and top lip of the rearward seal, but instead, up against them...it's just terribly out of line...i was told the window would have to come out so it could be pulled off and welded back on straight...Last edited by 95astrovan; 05-28-2008, 02:30 AM.
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...2 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...2 weeks ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...2 weeks ago
by AZ3.8CamaroI have a 15 year boy now (crazy how time flies from when I was a teenager on here!) and his first car will be the old Camaro.
I stopped driving...2 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...4 weeks ago
