This is a DIY style write up using inexpensive materials, and yielding great results. Now is the time to address that door ding or dent that has been bothering you, or repaint a badly oxidized body panel, and now you can do it with a tight budget.
It's divided into 3 sections: bodywork, painting, and color sanding.
The bodywork section can apply to any damaged area that is either fiberglass or metal. Front fenders and bumper covers aren't going to hold up well with body filler, but they are also much cheaper to replace, so I would suggest buying a new part, and skipping down the PAINT section of this, if you still want a little DYI in the repair. There is a few products out for plastic repair though, including a product by bondo, which is a viable alternative to a new panel, and is workable, although much more time consuming and precise.
Let's begin.
This is what I repaired:
What you're going to need for the bodywork section is as follows:
-a hammer and dolly (or dent puller, depending on the amount of access you have to the area) [for metal repairs only]
-Sand paper
-I would suggest 60 grit for stripping the paint, and you're going to need at least 220 to smooth it out once it's done.
-a flexible sanding plain (if working on a curved surface) [sanding block if a flat surface]
-your choice of body filler (I used Bondo, since it's plenty respectable and cheap, but it does take a little more work than other fillers)
-plastic spreaders
-a bucket for water
-a piece of cardboard
-*optional* a Dremel with sanding bits
Let's begin.
-Sand paper
-plastic spreaders
-a bucket for water
