Would cleaning out the inside of the headlights fix this? or is there any other way?
Yellow fogged head lights
Britney Spears is the HOTTest girl in the world!<br /><br />2000 Camaro 3.8L Y87<br />Flowmaster 80 American Thunder catback<br />Magnaflow Carsound Catalytic Converter<br />SLP Ram Air Cold Air Intake<br />Whisper Lid<br /> <a href=\"http://www.cardomain.com/id/freestylin59\" target=\"_blank\">http://www.cardomain.com/id/freestylin59</a>Tags: None
Re: Yellow fogged head lights
I picked up some headlight cleaner at Auto Zone and it said on the back of it about using (and I'd wet sand with it) 2000 grit sandpaper to remove yellowed areas. You may even try using some maguire's machine glaze and a wheel to maybe bring the luster out. I used a bit of that on the tail lights and it shined them up without any sand haze.
I loosely followed this write-up and it was a night/day difference. Used to have to use my foglights for additional light at night to see properly, they were so foggy. Novus is a really good polish product. I tried some Meguiar's PlastX Polish and other Autozone products, but they didn't clear up the plastic like the Novus kit after wetsanding.
http://www.ls1tech.com/forums/showthread.php?t=157192'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
you can do that ^
what i did was wetsand with 600 800 1000 1200
then got some polishing compound (same you would use on you paint)
and a buffed the lenses with a buffing wheel.
then used some wax.
-Y87
Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
