WTF am I doing wrong? I'm trying to clear coat my nightshaded tails to give them a bit more gloss; every time I try (on my 4th attempt now) it doesn't dry clear, it comes out grey! I shake the can plenty (roughly 2-3 minutes) and spray from about 8"-10" out. What am I doing wrong? I tried with some cheap (Krylon, IIRC) clear coat and thought maybe it was the paint, so I went and bought some Duplicolor. It always turns out a greyish color for me :( Does the paint need to cure first? (curing time is 7 days!!)
Clear Coat (spray paint)
Re: Clear Coat (spray paint)
How much time are you allowing between coats? When I did my signals I waited about 10-20 minutes per coat. Granted, I was also spraying it on a little thick. But a good prep job can make a world of a difference. Try wetsanding the paint with a 1000 grit before adding clear coat.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
I did wetsand (not sure on grit, but it was the finest I have) before, and no difference. I didn't think I was spraying it that thick, and I'm only doing one coat when it turns grey :(~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Originally posted by RadRacer View PostI did wetsand (not sure on grit, but it was the finest I have) before, and no difference. I didn't think I was spraying it that thick, and I'm only doing one coat when it turns grey :('99 Camaro
'04 Saab 9-3 Aero
Originally posted by Pewter2K1 View Postwhat brand paint are you using? clear may not mean crystal clear to some companies....
i only use duplicolor bumper and trim paint if the rattle can sprays on my car
Originally posted by pace2006 View PostDid you try adding any more coats of clear after this first "grey" coat, or did you stop there and sand it down again? Sometimes when you have only a coat or two of clear on the niteshade it looks more dull and has greyish spots in certain areas. That's how mine looked, but it was just thin spots in the clearcoat. I added a few more coats and it cleared up quite nicely.
Originally posted by IwannaCamarosoBad View PostIs it gray or is it just a dull color, I did this with mine and I was using some clear that wasnt doing so well with the niteshade.
Originally posted by Disruptore4 View Post"but it was the finest I have"... sandpaper can get very fine, almost to the point of feeling like a piece of looseleaf paper. you may have sanded with too large of a grit and it just won't be clear again... just my two cents. =/~97 3.8L V6 Camaro~
A few things
The probelm is nothing to do with the paint or sanding. Are you outside painting this? the problem is that it is to humid. when you paint in a humid place it causes the paint to "frost" over. ive had this happen many times. All i do is stand outside a door and spray a light coat, i then immedently move it inside our basement which is air condidtioned and has a de-humidifier. problem solved.
Originally posted by lilchubby View PostThe probelm is nothing to do with the paint or sanding. Are you outside painting this? the problem is that it is to humid. when you paint in a humid place it causes the paint to "frost" over. ive had this happen many times. All i do is stand outside a door and spray a light coat, i then immedently move it inside our basement which is air condidtioned and has a de-humidifier. problem solved.
i have noticed that clear coat in a spray can usually likes to "eat" things.. i have a set of rims that i painted and then tried to clear them a few days later, and the clear coat actually mixed in with the paint causing it to turn a dull grey color (i painted the rims fake chrome)
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...2 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...2 weeks ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...2 weeks ago
by AZ3.8CamaroI have a 15 year boy now (crazy how time flies from when I was a teenager on here!) and his first car will be the old Camaro.
I stopped driving...3 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...4 weeks ago
