94-97 vs 98+ camaro convertible back end differences - FirebirdV6.com/CamaroV6.com Message Board
  • 94-97 vs 98+ camaro convertible back end differences
    Can anyone tell me what the differences are between the back end of a 94-97 and a 98+ camaro convertible are?
    Can you change a 94-97 back end over to a 98+?
    Thanks,
    Brian
    Re: 94-97 vs 98+ camaro convertible back end differences
    well in general I think the 98+ have rear disc brakes and the tail lights are different
      i am pretty sure they are exactly the same.
      1997 Camaro LS1 RS
      1994 Camaro - Sold
      1999 Trans am Vert - Sold
      A Few Mods....
        the rear (frame wise) are the same, the only difference was the tail lights, brake lines (disk/drum) fuel pumps, fuel lines, and the SS spoiler was different from I think 94-95 maybe? but everything will bolt up fine. I have a 97 that Im upgrading the front end to the 98+ and the 98+ rear end but all of this is coming out of a 2001 Donor Camaro..
        MISC: 01 parts. Some interior, T top kit, seats etc.
        http://forum.camarov6.com/showthread.php?t=95347
          wait do you mean the convertible part only?
            The rear end of a 97 should be the same as a 98+, so you only need to worry about swapping the front end.
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
