question - FirebirdV6.com/CamaroV6.com Message Board
question
  • question
    just out of stupid curiosity i was wondering if it would b able to remove spray paint off panels using a steamer?? melt the paint off? or would that also melt the panel? just an idea
    Re: question
    just use a clay bar
      Re: question
      wait so ur saying to use a clay bar to remove spray paint from interior panels?
        Re: question
        You can buy some paint stripper from Lowes or Home Depot for around $8 or so man.
        ~97 3.8L V6 Camaro~
        A few things
        Only Member of Team Hooker?!?
          Re: question
          i used goo off to remove it and it sucked, is this any better than that?
            Re: question
            im talking about door panels too so would i just have to wipe it down with the stripper or put the stripper in a tub and soak the panels in it?
              Re: question
              Goo off isn't going to take it off if it was properly applied. With paint remover, you will normally spread it around the paint and let it sit for a while, (wide time channel depending on the circumstances) then remove it, and the paint will come with it.
              1996 Chevrolet Camaro
              1995 Buick Park Avenue Ultra
              --Appearance Moderator--
                Re: question
                yep just becareful, the stripper might eat/pit the plastic interior peices if its left on too long.
                ask me how i know.
                  Re: question
                  Acetone will do the job.
                    Re: question
                    lol well then how long should i leave it on then...any specific brand anyone recommends?
                      Re: question
                      use laquer thinner.. you can get it at autozone. it wont hurt the plastic, I wouldnt use a stripper. it might eat the plastic. its been known to do it, but some brands done.
                      Archer
                      MISC: 01 parts. Some interior, T top kit, seats etc.
                      http://forum.camarov6.com/showthread.php?t=95347
                        Re: question
                        Just put some on a rag and wipe off the spray paint. Don’t rub the area too long, but it does evaporate quickly. After just put some water on a different rag and make sure you wipe off the area for good measures. 30 seconds max for everything and you are done. :tup: Tip: Dont pour acetone on your car!
