berger idea - FirebirdV6.com/CamaroV6.com Message Board
berger idea
  • berger idea
    i like the look of the black Berger but i would want one in satin black not flat or gloss. (i want it to look like i wanted it to be there, not like i just cant afford paint that matches)
    keeping in mind that i will always look for a alternative method before i pay full price for anytihng....
    my idea is to go to a junk yard find a 4th gen camaro that's already black and has a berger with little to no damage. ill buy that one and use a **** load of rubbing compound to take some of the shine off to give it a the satin/semi-gloss look.
    then put it on my car, and not have to worry about finding time that i can take my car apart. and still have a red berger if i dont like the new one.
    am i a genius or an idiot??
    Re: berger idea
    ok, im confused.. are you looking for one or you just telling people that your looking for one and what your going to do once you get one? because you just made my brain hurt..
    Archer
    MISC: 01 parts. Some interior, T top kit, seats etc.
    http://forum.camarov6.com/showthread.php?t=95347
      Re: berger idea
      ok
      1.buy a black berger for cheap.
      2. apply rubbing compound to take away shine.
      3. swap onto car.
      reasons,
      1. have 2 bergers.
      2. dont have to pay someone to paint it.
      3. dont have to paint it myself.
      4. easy.
        Re: berger idea
        oh.. ok
          Re: berger idea
          Originally posted by Archer View Post
          oh.. ok
          dude my only reason for posting this is to get people's thoughts on my stupid ideas.
          so if you could tell me what you think....
          oh and btw the problem is def not getting one.
            Re: berger idea
            it'd work. id probally just sand the black one and paint it satin, but thats just me.
            ive seen people get black ones off wrecked cars and swap them on, easyer than painting it.
              Re: berger idea
              well I think your going in the right direction, but wouldnt it be easier to find one thats already black on the camaro, or really just spray it. and rubbing compound wont work to dull out the finish. your better off painting it, or buying one already black.
              want a pro look, cheap.
              go to body shop, purchase the red scuff pad. scuff the berger, go to autozone get satin black and spray it. from side to side with a 50% overlap. light coats, then wet coats.. no one would never know it was a rattle job..
              Lets see some pics when your done.
              Archer
                Re: berger idea
                maybe some like 1000 grit sand paper and then the compound?
                you said protected? as long is i dont take off all the factory clear wont it still be protected?
                and yeah i was thinking if i totally screw it up then ill try my hand at painting it. if i screw that up ill either give up or pay someone to do it for me.
                thats why i want to do this on an extra berger.
                  Re: berger idea
                  yea, i really recomend you just paint it. hell i spray painted my stock wheels and they look decent.
                  sorry about the dirty calipers
                    Re: berger idea
                    ^ That I like. I was thinking of doing the same. there is a guy around the bellevue area in here ohio that has his snowflakes spray painted all black and it looks GAY.. I like the silver lip much much better.
                    Archer
                      Re: berger idea
                      I got mine off ebay for $35. Came in and it was nearly flawless. Just had a tiny chip on the far left corner of the panel. Check a couple of salvage yards on there first, because the local ones around here wanted $80 for one.
                      Painting it's not too bad. If done properly and meticulously, it can take a couple days, but there have also been people who just sand it down a bit and spray it. Just depends on what kind of time and materials you have. Personally, I'd say just go down to Autozone and get some sandpaper, some primer and satin black paint, and spray the panel (once you get it). Either do it yourself or have someone else do it, it's not too hard. When it comes to appearance, you get what you put into it.
                      And just for reference, here's how my satin black panel turned out.
                      http://forum.camarov6.com/showthread.php?t=92885
                      '99 Camaro
                      '04 Saab 9-3 Aero
                      '90 Audi Coupe Quattro
                        Re: berger idea
                        Rubbing compound isn't going to may your berger turn satin black. It will just be FULL of deep swirl marks, which, in the right light, will look less glossy than stock. But in direct sunlight, it will look like really bad paint.
                        There really is a difference between satin paint and gloss paint that was scratched up to match it.
                        1996 Chevrolet Camaro
                        1995 Buick Park Avenue Ultra
                        --Appearance Moderator--
                          Re: berger idea
                          So you have a black Camaro, but you want a berger panel that is satin black? I don't get why....Unless I got this totally screwed around.
                            Re: berger idea
                            agreed,if anything it'd be a dull black, white light scratches in it. if you use anough rubbing compound to take away the gloss, your going to have swirls/scratches. theres no way around it.
                            i wouldnt even try wet sanding some of it away, you'd just end up with flat or semi-gloss at best. it'd look sun-fadded or something.
                            painting isnt that hard and you'd only need to spend maybe $10 on paint.
                              Re: berger idea
                              just go c/f on the berger :P
                              2001 Camaro 3.8 A4
                              1991 3000GT VR4
                              2001 Mitsubishi Eclipse GS
