drag rims - FirebirdV6.com/CamaroV6.com Message Board
drag rims
  • drag rims
    If I went with a 15" rim on my 96 camaro, what would be the proper offest and specs that I would need to look for in a rim? is 15x8 ok or should I be looking to get a 15x10 rim?
    Im looking at most likely going with a 255 wide drag radial at most.
    Also, I know someone a while ago had posted some really cheap drag rims taht they found at summit racing...just wondering if anyone has that link, or another link to cheap 15" rims that would work on the camaro.
    Also, I have drum brakes on the back, from what I understand, 15" should fit fine without having to grind anything off right? Only those with calipers need to grind?
    Re: drag rims
    If you want a 255 tire to fit all you would need is a 15x8 wheel. But if you ever want to upgrade to bigger tires I would just go head and get 15X10's.
      Re: drag rims
      what offset do you know? or does it matter?
        Re: drag rims
        shoot for 40-50 mm positive offset on the 8".
        I fit 15" wheels on my back just fine, just a tad of grinding on the wheel hubs, none on the car.
        1996 Chevrolet Camaro
        1995 Buick Park Avenue Ultra
        --Appearance Moderator--
          Re: drag rims
          you have drums right?
            Re: drag rims
            also...do I need spacers?
              Re: drag rims
              http://store.summitracing.com/partde...107+4294923105
              this is the rim I am looking at getting....less then $50 15x10 only thing is it has a -38.00mm offset....how does that make a difference? will that fit? will spacers fix that offset?
                Re: drag rims
                ok, how about a 15x8 5x 4.75 with 3.5inch back spacing....will that fit, and how will that fit on the car?
                  Re: drag rims
                  anyone...
                    Re: drag rims
                    Yes, it should fit just fine.
                      Re: drag rims
                      I heard I should get an 8 inch back space wheel?....so should I pick up spacers?
