VHT night Shade what do yall think? - FirebirdV6.com/CamaroV6.com Message Board
  • VHT night Shade what do yall think?
    I originnally had Blacked out turns signals and side markers and I had to replace the bulbs and Found out that the sockets melted. So I want to try VHT night shade and black out my turns signals and side markers again but I'm afraid the same thing will Happen again. Has any one used VHT before ?
    Re: VHT night Shade what do yall think?
    no matter how much clear i use over it i can never get it to last i hate it!
    2001 Camaro 3.8 A4
    1991 3000GT VR4
    2001 Mitsubishi Eclipse GS
      Just did my vette a few weeks back and havent had a problem yet!
        VHT'd my turn signals and marker lights about 5 months ago and they still look awesome. Just make sure to prep them correctly and go easy on the niteshade. Wetsanding can really make a difference too. Be sure to lightly wetsand between VHT and clear.
        '99 Camaro
        '04 Saab 9-3 Aero
        '90 Audi Coupe Quattro
          VHT is good stuff i love i have it on booth of my cars and the bike just take your time and do it right the first time
            nothing wrong with the vht stuff. it looks great done right... might want to practice on something first though. you can even get away without the clear if you have some skill with polishing.
            Visit My F-Body Page
              which 3m scuff pad do I use , Should I wet sand ??? I have the 3m sand blaster automotive sanding sponge paint preparation? Is this the right one ?
                What a sexy vette ....... :cool: Yeah I Slightly VHT'd mine ...... still on there
                  I had an extra set of tail lights for my GTO and I bought two cans of this from summitt to tint them. I'll start off by saying that this stuff will run on you if you don't take your time and do very light coats!
                  I learned the hard way. After getting a shyte-load of runs the first application, I tried to wetsand then buff them. The VHT stuff doesn't like to be wetsanded OR buffed! It can be done, it just doesn't like it. I stripped all of it off using Lacquer Thinner and started all over again.
                  The way I got it to work (without running) was using about 12 very light coats, and doing it out in the hot sun. After getting the coats to my liking, I mixed up some clearcoat and sprayed it on. I used about 3 coats of clear, waited about 1 week, then buffed to a phenomenal shine!
                  ...then I sold them :mad:
                  I have one picture of them I've attached. It was in their drying stage (after clearcoating, but before buffing). I put pinstriping on them 4 days after the clear was applied.
                    do I have the right sponge though ??? and what did you use to buff after the clear coat . did you use the microfiber
                      Tom RS nightshaded my turn signals and side markers and they came out excellent. You should ask him his process.
                        offhand I tinted my taillights.
                        mine are curved so I had to do alot of stretching and I hit them with a heat gun.
                        My dog approved, but I didn't. I didn't want to black them out I wanted just to make them more "marroon" looking So I removed them after a week. But they cam3 out pretty good, I think f-body or vette lights would be a joke to do.
                        Just make sure to get non-metallic tint, since it will stretch and go on more easily then metallic tint.
                          I don't know about sponges, but I'll tell you what I did when I VHT'd my turn signals and marker lights. First, I cleaned off the housings and lightly scuffed them with the 3m pad. Think I used something like a 200 grit for that, but don't worry too much about the grit. Then clean them off again. Make sure it dries and spray it in light coats as hockeyman mentioned. I didn't wetsand between coats of VHT, so I waited about 15 minutes before spraying another coat. A hair dryer may help to dry it if you don't want to wait too long. After it was dark enough I let it sit overnight and lightly wetsanded the VHT with a 1000 grit. Be sure to lightly wipe off any remaining dirt from wetsanding. Then sprayed them with clear, waiting about 15 minutes in between coats. Once they had enough coats of clear, I let it sit overnight and came back to lightly wetsand it again with 2000 grit. Then I polished it with some cheap Meguirs Plastx Polish and waxed it. Installed them and they've been good as new since.
                          '99 Camaro
                          '04 Saab 9-3 Aero
                            just saying guys...
                            mine was $10.99 from lows, 1-2 old credit cards, a spray bottle, and a razor.
                            Heat gun made it alot easeir, bought a heat gun for $9.99 from Harbour Freight.
                              Originally posted by DAS BOOT View Post
                              just saying guys...
                              mine was $10.99 from lowes.
                              Stretchable sheet tint?
                              Never seen it there. Not saying Lowes does't have it, I may just be looking in the wrong area(s).
