I bought these foglights from autozone, and I am planning on putting them behind my billet grill, my question is, is instead of putting them on there own little cheap switch that comes with it, how could I wire it up to come on with the factory foglights switch?
"hid" foglight question....
#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>Tags: None
Re: "hid" foglight question....
What do you specifically mean? Just, splice the wires? If thats what you mean, would having both sets of fogs possibly burn up the wire due to too much power? thanks!#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
If they're too high of wattage, you could just run a relay set-up too. That's what I would do; generally HIDs don't draw alot of power, so you might be fine, but I'd run it that way just for safety.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Originally posted by RadRacer View PostIf they're too high of wattage, you could just run a relay set-up too. That's what I would do; generally HIDs don't draw alot of power, so you might be fine, but I'd run it that way just for safety.'99 Mountaineer AWD 5.0 - 4300K HID, Some Bolt-ons
'97 RS - HPTuner, Bolt-ons
'09 WRX - Aesthetic mods
